The problem with the logo and menu
I can not change the logo. Loading a new logo to personalize the theme (Header Settings -> Logo), but it does not work.
I can not change the color of the menu. When I change the color of the Header Settings -> Main Menu "Links hover / active background color" is still a standard color.
How can I remove the menu transparency on a white background. Just as it is here: http://starter3.apollo13.kinsta.com/
