Change main and sub title pasword protected items
in FatMoon Posts: 136
Hi Guys,
a number of items (all bricks starting from British american tobacco) are password protected. see attach.
or go see http://bumsch.com
Main title:
When not unlocked the title says...
(lock symbol) this content is password protected
I would like the title to say...
(lock symbol) work item title
Sub title:
I would like the subtile that says....
Click and enter your password to view content
to say...
This content is password protected
    edited November 2016 Posts: 10,970
    Go to fatmoon\advance\utilities\cpt_work.php ~726 and change this
    			if ( post_password_required( $post_id ) ) {
    				$html .= '<div class="texts_group">';
    				$html .= '<h2 class="post-title">';
    				$html .= '<span class="fa fa-lock"></span>' . esc_html__( 'This content is password protected', 'apollo13-framework' );
    				$html .= '</h2>';
    				$html .= '<div class="excerpt">';
    				$html .= '<p>' . esc_html__( 'Click and enter your password to view content', 'apollo13-framework' ) . '</p>';
    				$html .= '</div>';
    				$html .= '</div>';
    			} else {
    to
    				$html .= '<span class="fa fa-lock"></span>' . get_the_title($post_id);
    				$html .= '</h2>';
    				$html .= '<p>' . esc_html__( 'This content is password protected', 'apollo13-framework' ) . '</p>';
    				$html .= '</div>';
    				$html .= '</div>';
    			} else {
    Check if it will work.
    Yes! Very happy with that! Thank you!
    Just one more question about this one.
    Can I delete the word "Protected:" in between the lock symbol and the title? see attach.
    Thanks again!
    1456 x 818 - 2M
    This is WordPress thing, so maybe try this plugin https://wordpress.org/plugins/remove-protected/
    Wow, that actually worked! Cheers!
