Thank you very much for this theme. It is wonderful !
- Is it possible to have all the default settings of the demo slider (first demo / slider with I am the starter on the banner) ? It is not easy to reproduce the same effects and find the same font ? Can you help me please ?
Edwige
did you import this demo to your website? What is your website url?
I am working on a local server on my computer. I use the demo but it doesn't charge the slider ? How can i do without loosing the content of my website ? What is the font use and the effect ? Thanks you very much for your help.
Please let me know which slider do you want?
I can send you only the zip file with a specific slider
With Regards
It is this slider : http://starter.apollo13.kinsta.com/ which mixed video and images. I joined also a capture.
Edwige
Download the attachment and install it using this option: http://nimb.ws/QzFVlq
With Regards
I am working in a local server, how can i upload the zip. Can i have to unzip it ? Thanks you for your response.
Normally it's located somewhere in php.ini file.
Look for something like
upload_max_filesize=15M
probably you have this set to '2M'
set it to like 10M
I delete the video to upload the file and i added after.
Thanks you for your advice.
