Hello, I use the demo one page and it is very easy to modify content. But i don't succeed to create anchor elements and to use a header menu like on the demo. Can you help me please ? Thanks you,
Hello Thanks you, it doens't seem to work. I think i do a wrong thing. I have on the menu "This row is pointed by:" only " Pick one" that appears. I fill a title in "Here You can add another Pointer for One Page Navigation" but i have default page on the header menu (Blog / Home / Works....) Thanks you for your help.
If so - please refer to http://apollo13.eu/docs/apollo13_framework_theme/#!/one_page
then please refer to http://apollo13.eu/docs/apollo13_framework_theme/#!/adding_menu
specially to http://apollo13.eu/docs/apollo13_framework_theme/#!/custom_post_type_in_menu
