Blog page header
I want my blog page to look the same as all the other pages. I done the same setup as all the other pages but no joy. I used visual composer elements on the blog page but these didn't save either? I have followed your instructions as well which was this;
Just set header for blog also in light version as you did for others. Customizing ▸ Blog settings > Posts list > Header color variant
David
    Ok, I think that a misunderstanding occurred.
    A header for us is a element that contains logo and navigation menu, and few other elements.
    For you it's the block above the content.
    So you should play around with section: Customizing >> Blog settings >> Posts list - title bar
  • Perfect, thank you.
