On your homepage it is from our theme, so you can easily change it in translation file, or source file if you need -> translation -> http://apollo13.eu/docs/apollo13_framework_theme/#!/translating_theme or in file fatmoon\parts\category-filter.php almost end of file esc_html__( 'All', 'apollo13-framework' )
As for second link, it is from Visual composer, you have to edit Default title in Filter tab, see screen shot:
Not by a certain option, but you can try doing this with custom css rule.
please provide exact page url where you want to achieve this.
Here ate the top, underneath the V logo
http://vincentdevries.com
And with all work items underneath the mail button. For instance here:
http://vincentdevries.com/work/brochure_tnt/
It is "All" from two different places.
esc_html__( 'All', 'apollo13-framework' )As for second link, it is from Visual composer, you have to edit Default title in Filter tab, see screen shot:
