Hi, I could you tell me how I can move the description of my project in the portfolio theme to be underneath the Image or Video instead of on the side. This is very important to me as I need my images to be as large as possible. Thanks and keep up the great work.
please check theme options in Portfolio section.
There is option "Description position". You have to choose Below icon option.
Best,
Miłosz
now I understand.
You need to edit single-portfolio.php file.
There is div#portfolio_info_content and you have to move it after div#portfolio_photos.
Then change css file to delete float and change width.
Best,
Miłosz
sorry for general tips but we are working on the new update right now and I can't find time to make this for you.
Try to make this on your own or please remind this topic after we release update.
Best,
Miłosz
I am preparing code for you right now.
Before that please download new version of our template.
It is still 1.6 but with one fix.
Best,
Miłosz
Thanks,
I have problem little problem with this. I will let you know as soon as I make it.
please replace this file with this on your server.
Best,
Miłosz
please download the newest version from your profile in the themeforest.
Then change template for in the themes admin in wordpress admin. You can use for this default Wordpress template. Then you will be able to delete Skyfashion from your blog.
After this click Install and select skyfashion.zip from your local disk.
Best,
Miłosz
