I have used wordpress for years and this is by far the first theme that is causing me confusion and issues.
1) I want to install the demo with the stock images - I followed the material and it still does not look like the demo. Can I receive some support with uploading the demo + images.
2) How do you edit the "connect" buttons on the top right. I want to change which ones show up.
If you need a login, I can create a new one if someone can upload the demo properly, and I should be able to take over from there and modify to suit my needs.
yes, please provide login credentials, send those via private message.
thanks for credentials, I need to check import files back and forth - I think there's a glitch inside.
Now finally you can play with it.
