Hi, I'm working on our new website using your fatmoon theme. There are two major issues we're facing. 1st: the general performance of the website is terrible. The loading times are sometimes beyond 15 sec. And we're not using any crazy images. Also, I turned off all the plugins we don't need. Additionally, I have another website running on that server and it performs just fine.
The other issue (might be part of the first one): the customization takes ages and sometimes it doesn't even work. E.g.: I can't customize the footer. Changes won't be saved etc.
Thanks. I can't get more that 7 second even after cache clearing. Which page exactly is so slow to you?
marko said: The other issue (might be part of the first one): the customization takes ages and sometimes it doesn't even work. E.g.: I can't customize the footer. Changes won't be saved etc.
What exactly you want to change?
Seriously? I can't really work with it... or at least it's very difficult. E.g. I'm trying to change the setting from 5 to 3 columns in our footer. Sometimes I simply can't press "Save", sometimes it works. But when I get back to the settings, it's back to 5.
I'll take a look at it.
What about the customization issue?
Which setting for footer is not working for you?
Could there any other reason for these issues?
