I had to change a css and I see my logo in the website disappear and the menu to fix this is really short. no options to fix the logo. what happened. I just rated your template with 5 stars....haha so please will you fix this?
Hi, did you change the color variant of the header to display? You could provide login credentials for admin user, send them to me via private message - I'll be able to react faster and more precise.
Hi, I changed only text colors in the footer like you suggested me to do. But the site on the sub-domain where I was building the site at first, on a totally different server, have the same problems and there I changed nothing after the migration. How can I send you a private message?
pfff how could I know that it has a effect like this! I normally deactivate all the plugins I don't use. Well everything is working how it has to work. Thx for your help!
Activate it.
Thx for your help!
