Discussions
Categories
Home
FatMoon
Lightbox on blogpost gallery / images
milesdeelite
January 2017
edited January 2017
in
FatMoon
Hi there! Is it possible to use lightgallery with images used in a single post? Right now it only opens the blank media image at maximum resolution.
I would be more than happy if there is a way to activate lightgallery for all images used in blog posts. Thanks a lot for any help.
Post edited by milesdeelite on
January 2017
Air
January 2017
Hello there:-)
Could you give me link to your example post, so I could see what constructions is there exactly? Maybe then I could figure something out, and it will be added to theme update.
milesdeelite
January 2017
Sure.
This one uses the standard wordpress gallery feature:
http://www.jenslumm.com/2015/09/13/kotau-at-festiwil-2015-wittlich/
Air
January 2017
I will check what can be done, thanks for pointing this out!
milesdeelite
January 2017
That would be awesome. Thanks a lot!
Air
January 2017
OK, I was able to make lightbox work with WordPress gallery in post, but no titles/captions will be displayed in lightbox. Are you OK with this?
milesdeelite
January 2017
Absolutely. Green light from me
Thanks a lot!
Air
January 2017
OK, will be added in next update, probably Monday:-)
Sign In
or
Register
to comment.
Sign In
Register
Quick Links
Categories
Recent Discussions
Categories
3.7K
All Categories
115
OneLander
324
PhotoProof
591
Rife
40
Agency
130
Starter
886
FatMoon
197
Thirteen
337
Photon
319
Chillout
769
Hypershot
3
General
January 2017
milesdeelite
January 2017
Air
Discussions
Categories
Sign In
