Embedded Video Aspect Ratio Problem
edited January 2017 in FatMoon Posts: 26
Hi there!
Embedded Videos do not resize correctly (screenshot attached).
All iframe videos do have a fixed width (800) and height (450) baked in. max-width: 100% will fix the width but the height will always be 450px.
I tried width:100% and height: auto but this will leave me with a height of 150px. So that won't be any help in single post view.
Examples:
http://www.jenslumm.com/tag/video/
Is there a way to fix that? Thanks a lot for any help.
Post edited by milesdeelite on
    Yes, this is work for JavaScript, as WordPress give em this dimension by default.
    Please try such fix:
    Go to fatmoon/js/script.js line ~117, find there:
    		runPlugins : function(){
    			//Resize iframe videos (YT, VIMEO)
    			$("div.post-media").fitVids();
    and change it to
    			$("div.real-content").find('p').fitVids();
    Please tell me later did this worked for you.
  • It worked. Thanks a lot!
    Thanks for info - added to update.
