( $header_search ? '<div id="search-button" class="icon-search tool" title="' . esc_attr( esc_html__( 'Search', 'apollo13-framework' ) ) . '"></div>' : '' ) .
natal1e said: In addition, I can still make a mistake. The header disappears when Iscroll the page down and then quickly scroll to top.
#header-tools .wpml-ls-legacy-dropdown { display: inline-block;}
It is possible, but you have to mess in code :-)
Place you are interested is in fatmoon\advance\utilities\header.php line ~291 All icons are defined around. If you know what you are doing you should be fine. If not, then I discourage you to mess around there ;-)
but
i still need your help, pls
i want use the WPML Shortcode: [wpml_language_selector_widget]
and when i insert this
( $header_search ? '<?php echo do_shortcode('[wpml_language_selector_widget]'); ?> ' : '' ) .
into the header.php
nothing goes... pls help
Link to site please?
About your main issue:
Do you have any cache plugins installed? Cause maybe this the reason why you don't see it.
for my first question: "new button near the the search button?"
i will sent u now a private message
For sure you can start with With kind regards.
