On my homepage: http://515.b22.myftpupload.com/ I have words that appear as if a typewriter is typing them. On mobile, it simply shows all of the words. I would like it to show just the last one. Is that possible? Thanks!!
Thank you! Yes, I agree that not having the scrolling feature of the words on mobile would be best. However, I would only like to display the list word. Instead of the entire list. Is that possible?
OK, now I get it:-) Lets try it with this custom CSS:
@media only screen and (max-width: 600px) { .a13-to-type.disabled-writing .sentences-to-type span{ display: none; } .a13-to-type.disabled-writing .sentences-to-type span:nth-child(3){ display: block; }
/* for better visual in your case you can add below also */ .a13-to-type.disabled-writing .sentences-to-type, .no-js .a13-to-type .sentences-to-type { display: inline-block; } }
I wouldn't advise to change it.
Unfortunately, that didn't change anything. I added it under custom CSS under the customize option. Do you recommend somewhere else?
