Good Morning,
I bought your theme and I would like to install an add on for slider revolution, but in order to do that I need the activation code of the plugin (
https://revolution.themepunch.com/direct-customer-benefits/#addoninstall).
Where I can find it?
thank you
When you have plugin bundled with theme you don't have purchase code for plugin. if you want to do waht you say you will have to buy license for Revolution slider on your own.
Read more https://help.market.envato.com/hc/en-us/articles/213762463-Bundled-Plugins
Can I also update the plugin? or I should wait the next version of your theme?
sorry if i'm bothering you again.
I activated the plugin and installed the add on.
I'm using the visual composer to add the slider in the page, but seems like it's not possible to have the background of the header transparent and change the color of the hamburger menu.
I followed the documentation, I tried to change the variants, but I would like logo to the left, hamburger menu on the right and the header (with the logo and menu) transparent.
here is the link: https://goo.gl/oz4bF7
if you want I can create a user for you.
thank you so much.
Your header is already transparent, but you have to set header to be displayed above revo slider. To do it edit your front page, Header -> Hide content under header.
As for moving logo left change header variant in Header settings http://apollo13.eu/docs/apollo13_framework_theme/#!/header_type
the row inside the column is set with full height row but the slider is not 100% height .
I also checked the revo slider and it's widescreen, so the issue it's something concerning visual composer.
would please let me know how to set the column or the row in order to have a hero revolution slider?
thank you so much
Im not sure in 100% because i dont see the slider settings but you can check this setting: http://nimb.ws/tFz5cp . If you see there any value like 50px or somethign else remove it and save the slider.
Let me know if it works.
With Regards
