Perhaps I understand wrongly. But the front page is based on navigation anchors? So each slide is a navigation achor, I've removed two of them (My works and tesimonials) but they remain on the front page. I haven't used this theme in a year, but want to use it again from scratch. I have been reading your documentation, but ti's not clear what I'm meant to do. Please advise. Thanks
If you want to remove a slide from home page - edit the home page and remove the content row. Slides are build with content that is contained by rows in Visual Composer.
More: http://www.apollo13.eu/docs/ceevee/#!/page_design
I think I have a better understanding of the theme now. Pretty great.
I have come across a different textual problem though, wondering if you can help.
I have attached an image where you can see the word ENGLISH drops to a sep line, however it shoud lbe on teh same line, as the previous one and not a new subject line. 'm not sure why this behaviour is the way it is, is there a way to append the word ENGLISH to the previous line?
I am using your default text, modified slightly:
UEL|2014 - 2015|MSc BIS: Pass|Modules: Project Management
Database Systems
Rapid Application Development
Computer Security.
UEL|2009 - 2013|BSc Computing: 2:1|Modules: Information Systems Modeling and Design
IT Planning and Infrastructure
Usability Engineering
Multimedia Design & Web Development
Database Systems
Research Skills
Advanced Information Systems Development
Project Management
Management Information Systems.
Newham College|2008 - 2009|HE Diploma: Pass|Computing
Mathematics
English
The above text is what appears when I click save and update. So it looks correct, but for some reason theme is dropping ENGLISH to its own area.
Please advise, thanks in advance
