Remove white bar!
I'm trying to set a slider revolution as a banner image on a single work page but it keeps leaving a white gap at the top of the page. Do you know how I can remove this?
Nathan
    Hi there:-)
    I will send your question to Daniel as he know this content stuff best, but could you leave link to page where it happens, so we will have more info about it?
  • Thanks, could i send the link privately in some way as its an unlaunched site?
    click on my nick, in top-right corner you will find option "Message"
    I think part of the problem is Content top/bottom padding option so you can fix it as described here http://support.apollo13.eu/discussion/4359/white-space-in-header
    Second part is probably padding in column where you put Revo Slider in Visual Composer.
    Edit column element, Go to Design Options, and set Padding to 0 -> see screen shot.
    1354 x 646 - 60K
  • Lovely stuff!! Thanks for your help
