Footer Widget Size
Hello Apollo 13,
How can I Change the width of the footer widgets. As you can see in the attachment I want to change the width of the twitter widget. it's now 200px and I would like to set it to 300px. (Only for that widget) Hope you can help. Regards, Jasper
    We don't set it to fixed width, but we set it fluid depending on how many columns you set in settings : Customizing ▸ General settings ▸ Footer ▸Widgets columns number
    Set it to number to suits your needs.
    Thanks! Works great!
