I’m struggling to design the blog page how I want it to look, there seems to be no options to add page elements to the posts page? Is this locked down within the theme if I select the page as 'posts’? Ideally I want to add and an image header that matches all my other pages rather than just the plain black Blog text.
Have you tried Customizing ▸ Blog settings ▸ Posts list - title bar ?
Hope this is what you are looking for:-)
Font face you set in http://apollo13.eu/docs/apollo13_framework_theme/#!/fonts_settings
Colors/sizes you should be able to set in same options of title bar.
I am at home already, but I will check tomorrow is there an easy customization that will alow to add content at top of blog page, what do you think about it?
If possible I will also add it to next update.
1. Install this plugin https://wordpress.org/plugins/add-editor-to-page-for-posts/stats/ to enable editor on blog page.
2. Go to file fatmoon/index.php line ~75 and before this code: Insert this: Now you should be able to add content to blog page.
