Header tranparency
in FatMoon Posts: 16
I install the website on my server. When I switched to the client server the header that was transparent went blank. I use the "Variant light - overwrites" and the setting is transparent. How do I make the menu trasparent as it was before?
    Have you refreshed user.css file? You can delete it (fatmoon/user/user.css) and see if it will help.
    If not, please send me link to this page.
    Yes, I did. But still white. I can change de colors, but not transparency:
    http://309.3a3.myftpupload.com/
    For me it is red when I view page. So you were able to change it?
    Then now set it opacity level to 0, cause what is on your screen shot is no color at all not transparency.
    See this: image
    394 x 426 - 56K
    Wow! It Works.
    Thanks for the support!
    Best Regards.
