Hi Air,
In the single works page, I have the feature image for that work piece as a full width image across the top and the title of which sits on top of that.
I have a bit of custom HTML I would like to add so it shows a scroll button to force people to scroll when on a mobile, as the image takes up the full screen.
The HTML and CSS is already set and I am using this on the homepage currently with no issues, however this is set as custom html within the containing div for the image on the homepage that I added into the Visual Composer, so it was pretty straight forward to do.
As the single work template uses the feature image function over something within a Visual Composer element, can you please tell me where I can find this function in the php file to add my custom HTML? That way whenever I add new work projects, it would dynamically pull in the code to load the scroller thingy.
Here is the code I have for adding so it creates the button to scroll:
<div class="swipe-down-mob"><a href="#scroll">
<div class="finger-mob">
<div class="scroll-mob"></div>
</div>
</a></div>
And essentially it looks like this:
https://cl.ly/3R371r422U29/Screen Recording 2017-03-16 at 11.38 am.gif Therefore I just need to know where and in which template I add this to load this scroller. Its set with Media queries so will only load on a mobile etc.
Try in fatmoon\advance\utilities\layout_parts.php line ~702 before
$html .='</div></div></header>';
add this Hope this will do the trick.With kind regards.
