Remove Transparent Header Bar from Album Lightbox
in Photon Posts: 33
Hello, I would like to know if there is a way to remove the top transparent bar from the lightbox. I don't mind the menu items, I would just like to turn the transparency to 0%.
Thank you!
Yog
    Go to Appearance -> Photon Advanced -> Miscellaneous settings -> and there you can edit various colors of lightbox.
    Thank you, that helped!
