Change fontsize for header - Work pages on mobile devices
Hi :-)
I have an issue once in a while when using long words in headlines.
If you see the attached screen dump - you can see how the headline breaks long words on a mobile device. If you are on a computer you can see it look fine here: http://www.martinkaufmann.dk/work/killiehuntly/
My question is... can I reduce the font size used for headlines in Work - only for mobile devices. And How do I do it.
Thank you in advance.
All the best,
Martin
    You can use this custom CSS:
    @media only screen and (max-width: 600px) {
    .single-work .title-bar.outside .page-title{
    font-size: 30px;
