This is only for our demos purpose, but you are second person to ask about it. You know what, I will add it to my TODO list to enable this for you guys :-) However for you, I will have to add some more options to it. Probably in next version.
Meanwhile you can search for plugins that give similar effects.
haha, thx! :-) ok, I'll search for a plugin. You don't happen to know a good one? And how do you call that feature? is it a side-bar or not? grtz! Anneleen
To be honest I don't know :-) I added it to my TODO as " floating i " However "Floating sidebar" or "hidden fixed sidebar/box", could be something close.
grtz!
Anneleen
