When I installed this theme the settings worked well, but after, some functions stopped working, I can't access the main settings. When I click on the function in my dashboard appears this error.
PHP Warning: Invalid argument supplied for foreach() in E:\home\otaboo\web\blog2\wp-content\themes\spaceship\advance\admin\print_options.php on line 304
How do I fix?
tks!
Need much more info for any assumption from my side. Good start would be to write all things, like mentioned in link in my footer. Second, it would be great if you could reproduce your issue on live, public server.
I don't know what version of PHP you use, but it seems it has something set that fails when argument for foreach is undefined. Try this solution: go to \spaceship\advance\admin\print_options.php on line 304, change
to:
if(isset($option['pre_options'])){foreach( $option['pre_options'] as $html_value => $html_option ) {
echo '<option value="' . esc_attr($html_value) . '"' . ($html_value == $selected? $selected_prop : '') . '>' . $html_option . '</option>';
