[Solved][Reponsive design] Thumbnail pixelated
edited April 2017 in Photon Posts: 8
To display an album, I use the brick display. I noticed that on mobile, it showed the same absolute size of thumbnail, which makes them very ugly.
How to have a responsive display with pretty thumbnails?
Post edited by Alix on
    Could you post link to your site so I could inspect how it behaves?
    Have you made some alteration in theme code? I can not find various things, that was responsible for bricks behavior.
  • edited April 2017 Posts: 8
    I removed the footer and the hidden basket that's all.
    OK, I understand now. You have inserted 5 columns, and we have only responsive styles written up to 4 columns.
    OK so for you best would be to use such custom CSS
    @media only screen and (max-width: 600px) {
    /* 1 column */
    body.single-album .bricks-frame .archive-item{
    width: auto !important;
    it should fix it for your case.
    Thanks !
    Nice support :)
