/themes/photon-a13/advance/apollo13.php
$import_data = unserialize( base64_decode( stripslashes( $_POST['a13_import_options_f ...
$import_data = unserialize( base64_decode( file_get_contents( $set ) ) ...
$import_data = unserialize( base64_decode( file_get_contents( $set ) ) );
... ata = unserialize( base64_decode( file_get_contents( $set ) ) );
$current_sidebars = unserialize( $this->theme_options[ $options_name ][ $opt ...
$fh =
@fopen( $file, 'w+' );
/themes/photon-a13/advance/cpt_album.php
$output = ob_get_contents();
This is proper theme code. Can you explain more about this topic that you created?
I know that it is now discouraged to use this functions, but when Photon theme was released it was OK to use it.
I wonder, maybe your antivirus plugin find it suspicious now cause I was in Editor in WordPress, cause I wanted to see if I can debug this issue without FTP access. I don't remember now if I edited anything, but rather not , cause file I was interested in was not visible from editor level.
I don't know this plugin, so can't tell why it fired after my login.
Anyway if you don't believe me, then please download again Photon theme from ThemeForest and compare if files are the same as in your installation.
