Css conflict
edited April 2017 in Rife Posts: 127
Hi !
There is a conflict between the css of my forum plugin theme and rife theme.
They told me to ask you how to handle this.
I tried to modify this plugin theme, but it seems to be overwritten by yours.
Here is the css file : http://www.contentologue.com/formation-blog-professionnel/wp-content/plugins/wpforo/wpf-themes/classic/colors.css?ver=1.2.0
And they told me to set this :
#wpforo-wrap .avatar{position: relative !important;}
in order to fix the avatar problem shown in attached file.
Thank you !
    Hello there Sophie!
    As I can't view your forum I can not easily test it to advice best solution.
    Have you tried adding this CSS they gave you to custom CSS?
    It seems that their CSS should fix this issue.
    I can change theme CSS, in next version, to be more specific to not target forum avatars.
  • It works perfectly ! I didn't know I could use forum attributes in your theme css. Thank you !
    It is general use custom CSS field :-) However active only when theme is active:-)
    With kind regards!
