Hi, since i just updated the Photon Theme and wordpress to the latest version, my frontpage don't work anymore...
http://sylvaing.net-2-sky.comI tried to downgrade the version of wordpress, and it is same.
There is a issue somewhere. Please help us to have our website back to the normal.
We have credentials for you, in order to connect. Please mail us to see for our request, this is quite urgent.
Thanks for your support!
Regards
It looks your site doesn't load any JavaScript files now and this is source of issue. I suspect some plugin, or broken cache.
Have you tried disabling all non theme plugins?
Anyway, thanks for your help and support!
However it depends what version you had previously.
However I am glad you have found solution!
