Hi. I have problems with loading the Works grid on the home page. I have found two issues that might cause the
Failed to load resource: the server responded with a status of 403 (Forbidden) - XXXX/admin-ajax.php
Failed to load resource: the server responded with a status of 404 (Not Found) - XXX/wp-content/themes/a13agency/js/light-gallery/css/lightgallery.css.map
If this will not help, then probably something changed on the server. Have you changed there anything lately, like permissions ?
