I'm looking for a way to add tool tips for the images that are brought in via album-list (front page). Simply adding tool tip plugin adds markup on the page and extra space- is there any way around this? Thanks in advance.
I don't think such plugin would be compatible with our Albums list. It would require some custom work. Can you tell me name of the plugin that you use?
