RE: Thirteen theme.
Having an issue with the slider on my home page when viewing on iPhone 7. Everything looks fine until I click on the about page template and then click back to the home page, the slider images look smaller. This is also happening on the demo -
http://thirteen2.apollo13.kinsta.comIt only happens with the about page. If I click on any other page and go back to the home page, the slider is fine.
Look forward to your reply.
I understand you use "back" function to get back to home, not clicking "Home" link or logo?
Do you mean that footer is cropping slider after getting back, cause it is only thing I can see.
Yes that's what I mean, footer is cropping the slider. It happens when clicking browser back button, home link and logo as well.
I am not sure which part is doing it, but it seems that Visual Composer is removing
height: 100%;fromhtmlelement and this causes issue.Anyway easiest way to avoid it is to disable ajax option http://apollo13.eu/docs/thirteen/#!/ajax_settings
