Works not showing
in Agency Posts: 8
For some reason works arent showing after i click on them..the lightbox just goes grey
any help?
    Hello there:-)
    Hard to say without any link. There is a chance there is JavaScript error.
    Can you post link?
    Ah my bad - http://nmdcreatives.com/
    OK. Your custom links in works leads to different sites. Different sites can not be loaded with this ajax box(cause of browsers security settings), so if you want them to work, then you have to change how your works open:
    Customizing ▸ Works settings ▸ Works list ▸How to open work▸ Normal
    Hi Thanks for getting back to me.
    I tried what you suggested and even though its turned off it still tries opening the ight box and doesnt work...
    Try disabling and enabling few times before saving. Sometimes settings get stuck in JavaScript.
    If this still will not fix it, then I will take a look.
    Hi thanks i did it acouple of times and it did the trick -
    A new problem i had is i tried dropping social icons from the header by deleting the names and they still appear at the top - any thoughts?
    attached an image
    1249 x 528 - 68K
    In each case I can see in source that there is 1 or 2 spaces left in these fields. Be sure you have them empty.
