Two column contact
Hi! I have the two column contact page set up, but for some reason, the photo is too big or something??
http://www.chrystalain.org/get-in-touch/
when you view the page on a normal size (?) screen the photo runs to past the bottom of the right column (as the background would)
shouldn't the white column on the right move get longer with the responsive design as well? it only goes so far.
Any help would be a plus!
Thanks,
Chrystalain
    Hello Chrystalain
    1) About the background, you must crop the image like on my screenshot because it is too high: http://nimb.ws/wKP3sx
    2) About the second part and the column, you probably have another empty ROW under the this column. Try to find it and delete it.
    With Regards
    Lead Graphic Designer
