Category filters are not showing if page text box is empty
in FatMoon Posts: 48
as you can see in the screenshot:
if i write something in the page text block, the filters are shown.
Otherwise they are hidden, how can i fix this ?
    edited July 2017 Posts: 10,970
    Link would help here a lot.
    I am not sure, but I believe they are just hidden under header.
    Try option Customizing ▸ Albums settings ▸ Albums list ▸Hide content under header ▸Turn it off.
    here is a link:
    http://www.cyrilpreiss.com/
    Hide content under header is turned off, and album list filter is enabled
    I see one category have showed up. I think you have to refresh categories in album, as they sometimes get corrupted after import. Just simply go and edit each album with different category, and click "update".
    indeed, it's working now, thanks !
