Is there a possibility of extending the width of the image in the post header so that it occupied the entire width of a post page, not only the central portion of it?
Also I've got trouble setting up a main page using Full Height Slider (this vertical "slices" of a photos looks awesome) but all I'm getting is normal photos (landscape oriented) with a slider option. Is Full Height Slider working only with portrait oriented photos?
Cheers,
Bartek
So you have bought this theme? ;-)
1. I understand that you use post without sidebar, right? For now it is no option like, however maybe it should be added ;-) Go to single.php file and try changing line 16
with this I will try to add it in next update also.
2. Set all album settings as explained here http://apollo13.eu/docs/hypershot/#!/albums_menu_slider_look . You can also show how does your page look(link)
Thanks for the help with the header photo. Working like a charm :-)
2. Yeah, I saw the settings in the documentation but it's not working for me
2. In my screen (1280x1024) it looks like it should, but now I think, that you might wish to get result as in our slider in black version http://themes.apollo13.eu/hypershot_dark/? Then You have to make portrait photos as album covers. Maybe that is not obvious, but we don't do any tricks with covers, as one would want to get wide covers and the other one would want tall, so we leave it in user hands :-)
Thanks a lot guys
