Ok, this one is silly but I always fail trying to set it up. I've got a blog post just like here for example -
http://buzuk.civ.pl/tydzien-z-ricoh-gr-digital-iv/I inserted few photos in the text. How to make them appear in lightbox like other photos from albums (or wordpress galleries). I try to install lightbox plugin and it worked but also collided with Hypershot lightbox (both appear in the same time, one on the top of another).
Cheers,
Bartek
You just have to insert them with shortocodes -> http://apollo13.eu/docs/hypershot/#!/shortcodes Typography -> Image with lightbox. If you wish to use own lightbox this one might not be easy.
Now I don't see any lightbox in your post. Could you please tell what plugin you use to add lightbox, cause it is odd that theme lightbox is runing with it along.
As for the lightbox plugin I tried (I already delete it since it collided with theme lightbox) it was ColorBox (http://wordpress.org/extend/plugins/jquery-colorbox/)
-B.
You are interesting 'testing subject' I must say:-) I have never imagine that this things should be explained farther, but I must have just been lucky up until now that no one asked about it:-) I will try to cover this subjects in documentation with update(it will be released in next week). Thanks
I always use [b]File URL[/b] so I was sure that it was already set and did not bother to check it. Shame on me
Thanks a lot :-)
