Is there a way to turn off the sticky property of the work info on the left side of the individual work pages? We would like to have it stay at the top of the page and scroll up and disappear when viewing the lower parts of the page.
See example here:
http://www.lucidarc.com/work/pleasant-street-residence/Thanks.
There is no option for this currently, it would require modifying JavaScript.
If you use full width rows from Visual Composer, then I would advise to recreate something similar with Visual composer instead of using build in info mechanism, as it will get in they way as you can see :-)
