I have a problem with The Thirteen theme.
When I watch the website (www.glasinloodhaarlem.nl) I made for a friend on a Smartphone or Ipad and I turn the device, the menu stays open when I click on something in the Menu. It will not close the menu after clicking.
I also can't put the content in the middle of the content page. It is not in the middel but it is down on the content page. So I have empty space on the top.
I hope you can help me.
Regards,
Mario
I would need to ask you to explain it in more details, maybe screen shot?
Do you mean you would like to make it middle of current visible screen like here for example http://rifetheme.com/rife-6/about-centered/ ?
Yes I like it to have it on the middle of current visible screen. Now I have a big empty space above every current visible screen. It needs to be in the middle.
Hope you can help me with both.
With kind regards,
Mario
You can place your content in the middle in just two clicks,
check the screenshot: http://nimb.ws/vN4eaL
With Regards
Please add this custom CSS and it should be better: Please tell me what do you think.
I knew how to put the content to the middle in the settings, but it won't change. Please check yourself. www.glasinloodhaarlem.nl or the two attachments. There is big empty space in the top.
It looks that you have set some big padding in row settings, like 200px. If you will remove it, it should be better. Go to tab "Design option" and remove it there.
My friend called me that the quarter turning phone issue/bug works also, but not with the iPad. So can you give me a custom css for that to?
Kind regards,
Mario
Also now I see problem with where you have added custom CSS. Please use theme field for it http://apollo13.eu/docs/thirteen/#!/custom_css_menu
