Homepage: Swap other design homepage into current activated design
Dear Sir / Team,
Recently, I purchased the fatmoon wordpress theme.
I am a UX/UI designer, But I don't know wordpress-admin.
My Question is,
My current design is 'Ottawa', But I need a different homepage for this like from 'Montreal', Hudson' homepage. Is it possible, then please assist me.
Thanks,
Rajasekaran
    Hello there:-)
    We have recently wrote article explaining how to easily swap designs in Rife theme. It works exactly in same way in FatMoon https://apollo13themes.com/switch-designs-rife-theme/
    However I believe you want to change your homepage more then design, so for that you can switch your homepage to about us 2 http://rifetheme.com/fatmoon-ottawa/about-us-2/ and work on it. You can swap homepage as expalined here http://apollo13.eu/docs/apollo13_framework_theme/#adding_frontpage
    Tell me does it help?
  • Thanks for your assistance,
    Actually, I am aware of this thing. But my Question is Currently I am in 'Ottawa' design - It is activated. I just want to import only the home page, portfolio page for example homepage from 'Osaka'.
    If I start the process with design importer as per the setup with import configuration. - Once I click the import button (Other design - Osaka) - What happen?.
    The current activated design - Ottawa' is change or not?.
    If anything collapse happens at the time of import other design? Because I don't want to change the Ottawa design. I just want to import pages from other design.
    Please assist me.
    Thanks,
    Rajasekaran
    edited October 2017 Posts: 10,970
    OK, if you just want pages from other demo then in Design importer select options:
    Import demo content & Clean up after import
    Pages will show up in your admin panel after import.
    My case is exactly the same as this.
    I have my client's site ready and I just want to modify the homepage of the LONDON theme to the homepage of the OSAKA theme.
    I did import demo content & clean up after import and nothing happened.
    I checked the log and this appears:
    Page "Home" already exists.
    How do I only import the homepage of the OSAKA theme for my site?
    Thank you and I await feedback.
    Vanessa
    Hello there:-)
    In this case, try to removing your page named "Home" first, and remove it from trash also.
    Then it will be able to import.
    Hope that help :-)
    Hello again,
    Follow your suggestion, imported the homepage of Osaka but the characteristics of the slider, as well as the layout of the top (logo, menu and social networks) are those of the London template.
    What my client wants is precisely this change: the top and the slider of Osaka, the rest of the info on the homepage is to leave.
    Waiting feedback
    Vanessa
    I am not sure I understand you precisely here.
    So you want just look of "header" (logo & menu part) from Osaka? To get it, do it as explained here https://apollo13themes.com/switch-designs-rife-theme/
    This will import only settings of Osaka Design.
    However, you can achieve same thing by just switching few options in
    Appearance ▸Customize ▸ Header settings ▸ Type, variant, background :smile:
    Variant - One line, logo on side
    Content width - Narrow
    Next in Customizing ▸ Header settings ▸ Main Menu▸ Main Menu▸Enable
  • edited October 2017 Posts: 20
    Thank you. Really helpful.
    Post edited by fizzy on
    Last question, do you know how I can switch off the preview video on the Home page of Osaka. please see the image.
    3152 x 1640 - 1M
    fizzy said: I can switch off the preview video
    From what i see you want to disable preview image, right?
    You can switch between different arrows here: http://nimb.ws/AK0MPZ , just select one without the preview.
    With Regards
    Lead Graphic Designer
