1. Which design you have imported? 2. If you go to Revo Slider menu are there any sliders? 3. It seems something is not right, cause we don't have such named Revo Slider in our designs. Can you send link to your page?
I think you have gave me wrong URL, but I have found your site:-)
I have just viewed it and it looks fine. Please try to view it as not logged user, or on different browser/computer. You can also use private mode in your browser for it.
Anyway if you still see error then I suspect that you can have some caching issues.
Don't worry we will find out where is the issue.
Do you have any caching plugin installed?
