changing the name of the blog
Hi, if I change the blogs name to news or anything else but blog, it kills the page. Where can i change the name please?
    Just rename page that is named "Blog" :-)
  • that doesn't work..
    1660 x 1346 - 88K
    How is your screen shot connected to case? :-)
  • when i change the name of the page, that happens
    That is strange, but as I remember you had same issue previously.
    How did you solve it then? I gave you such solution then https://support.apollo13.eu/discussion/comment/20685/#Comment_20685
    Do you have any cache plugins installed?
  • that was a different issue as I wast looking in albums and trying to use the rev slider.
  • you are welcome to sign in to have a look?
    But you also have seen error about Revoslider that you shouldn't have at all.
    But sure, I can take a look.
    Could you please send me temporary access to your WordPress ? Send it here on forum via private message(click on my nick, in top-right corner you will find option "Message"). In message please add LINK to topic it applies to.
    Thanks for data. There was no issue with renaming, no error when I did it. It is called "News" now.
  • don't know why it was doing it to me thanks anyway :)
