Core File Modified - Error
in Rife Posts: 38
Hi, I hope you are doing excellent.
I have an error after the last updating. Attached you will find the image. When I try to fix it the pop-up message is "We could not write to that file. You may not have permission to modify files on your WordPress server."
This is also making a conflict with akismet plugin, which is not listed at the plugins menu but the folder is already in wp-content.
What do I have to do to fix it?
Thanks.
    Updating:
    I just ran the scan again and the error desappeared, then I erased the complete Akismet folder, re-installed it and it is running fine (apparently).
    Thanks.
    Hello!
    Thanks for update.
    However I don't think I will be able to help you with this, if this was not connected to theme.
    Such topics are good for general WordPress support forum.
