Thanks ! I have another one quesiton, I think just show my blog part of my wordpress, it's possible to hide the menu ? I have not find the option. Thanks.
Do you mean to hide whole header part? There is no option to do that from theme. You could probably do it with custom CSS, but how would user then move to other pages?
Yes, I will test ! They are not another pages that blog. I will used widget to add a main link. Thanks.
And since yesteday, I have a problem with the modification. I can't modify the social icons, it's not saved. The case 'published' or 'save' is not active. I have try on Chrome, Safari, Firefox etc..
Check this https://www.mhthemes.com/support/open-wordpress-menu-items-in-new-tab/
