About the Resolution
On the Macbook Air 11 inc, the website has a white frame which makes lose part of the visuals / components like you can see in the attachment (For instance, look at the upper left corner on the Contact page).
Is there something that we can do to avoid this?
Thanks,
Fırat
    Hello there:-)
    Do you want to remove frame, or make sure that map will be visible when frame is there?
    Content in theme generally respects this frame, however some plugins may use JavaScript to stretch content beyond limits.
    What do you use to setup this map?
  • Thank you for your reply.
    Normally, there is no frame on the website. It’s about resolution probably. And yes, is there a way to make the website fit into screen?
    And yes, the map is also another problem. It’s the default Contact module that came with the theme. I just pasted the link into the form. Normally, I mean with other resolutions, it’s all looking good.
    edited December 2017 Posts: 10,970
    If you want to remove frame then go to Customizing ▸ General settings ▸General layout ▸Layout type : Full width
    This should solve issue:-)
