Set different number of columns for products list and related products
in Rife Posts: 2
Initially, I had number of columns set to 3 on the shop page (Products List). I changed it to 2 columns because it looks better. However, when I view the related products on the Single Product Page, I notice that it has also changed to 2 columns, but I would prefer to have 3. How can I enable this?
Many thanks,
Aero
    Hello there:-)
    It sure is a bug. I will fix it for next update, however for know you can do such change in code:
    Go to rife\advance\utilities\woocommerce.php line ~285
    and change this
    function woocommerce_output_related_products() {
        $args = array(
            'posts_per_page' => 3,
            'columns'        => NULL, /* empty so template will decide */
        woocommerce_related_products( $args );
    to
        $args = array(
            'columns'        => 3,
    Thanks for reporting this.
    Thanks, works great!
