Please provide more details about this header (link to your page or our demo) because some headers were built using the Visual Composer and other using the theme settings.
In my opinion, it's one of the worst VC element and yes, you can't change the font settings for this VC header. You must add the CSS code to make this element bigger. Try this one and change 22px to your desire value:
.vc_separator h4 { font-size: 22px!important; }
You can add this in the customizer Custom CSS tab but also in your selected page: http://nimb.ws/iP3IoD
Hi Daniel, sorry to bother you again. Similar issue with the footer. Below contact us and also in the events list. (which is another plugin, but seems to get the font settings from the footer. I can only change the header size in the standard customisation. Thanks, Paul
Default theme headers size: http://nimb.ws/29r7sF
With Regards
it's at http://www.lucoled.com
I tried the changing default header style but it's not changing anything. I think it's the standard VC seperator with text.
Thanks,
Paul
.vc_separator h4 {You can add this in the customizer Custom CSS tab but also in your selected page: http://nimb.ws/iP3IoDfont-size: 22px!important;
With Regards
Thanks,
Paul
Please go to Customizing ▸ General settings ▸ Footer ▸ Font size in widgets part - there you can adjust font size.
