Problem displaying on mobile and with page name on fb.
edited January 2018 in FatMoon Posts: 7
Hi ! I am using fatmoon theme,
And have problem with display on mobiles. There id a white comun appearing on rights side of page, cutting off half of photo.
Theboyher thing id that when I post my website address on fb Ken Burst Effect appears instead of thumbnail .
I've changed page identity, but nothing changed.
Page address is www.przemekpaczkowski.com
Thx in advance.
Post edited by paczk on
    In case of FB you have to use their tools to clear their cache for sites like this one https://developers.facebook.com/tools/debug/
    Use it whenever you change something that should affect how your site is displayed in FB. Also if you plan to share albums I advise to use Yoast SEO plugin to tune your setup & better control of how it is shared https://wordpress.org/plugins/wordpress-seo/
    paczk said: have problem with display on mobiles. There id a white comun appearing on rights side of page, cutting off half of photo.
    I see that some plugin is adding extra styles messing up slider.
    Please add this custom CSS to fix it. I will add same in upcoming update:
    .slider-slides img{
        max-width: none !important;
    Thanks for reporting this.
    Hi again ;)
    thx for your support,
    where should i put this ?
    to slider ?
    best ;)
    Please add it as explained here http://apollo13.eu/docs/apollo13_framework_theme/#custom_css_menu
    OK I got it :) -
    Again - you' ve done great work !!
    thx a lot !
    See ya :)
    Przemek
