I'm getting lot's of errors suddenly when I try to login: The log gives the following errors:
PHP Fatal error: ThemeUpdateChecker::injectUpdate(): The script tried to execute a method or access a property of an incomplete object. Please ensure that the class definition "ThemeUpdate" of the object you are trying to operate on was loaded _before_ unserialize() gets called or provide a __autoload() function to load the class definition
Check what version of wordpress you are using. Hypershot is compatible with wordpress 3.4 and up. If that is not the case please show link to your project so I could see it.
Now everything is working again.
Check it and write back please. Commenting out code is not good solution ;-)
But like I said I didn't change my Wordpress installation in the last 24 hours. The last change I did was adding the wp-facebook-open-graph-protocol add-on, but also after removing this one (and almost all other add ons) the problem was persistent.
My site: http://vannuil.com
I have a question how long do you use Hypershot?
Cause about 12 hours ago, we have released update, and update script might detect it, but why it would crush your WP is a dark mystery for me at the moment :-)
Thanks for any help with resolving this one!
I will keep my eyes open on this issue.
Thanks once again for reporting it!
