Hi My site worked fine with Ceevee 1.0.10 theme for several months, But after WP upgraded to 4.5.3 my site show blank page!! But after I logged in to admin panel I can see the site and admin panel! What should I do?
Hey there, I was out of the country for a while, and just updated all my wordpress and now my website is not functioning, and I was not able to update to v1.1.0 and i can't find it anywhere! what should i do?
What version number of WPBakery page builder you have now installed? I will send you update on same e-mail as theme update, but please tell me if you received previous e-mail?
it says i have installed V 4.8.1 and when i try to update to 4.12.1 of WPbakery it says it is up to date.. but then it is not and redirects me to purchase it.
Hmm, then I am worried that new version that I am about to send you will work OK, as it is version 5.4.5. Unfortunately developer of CeeVee left us long ago, so can't tell if will work flawless. However it should :-)
Anyway try to remove you current version of plugin, and upload one that I will send you by e-mail.
I was wondering if the theme is completely dead with the new word press update?
I cannot seem to do anything, and looks difficult to update. Is there any other similar theme to this? I really love the whole theme and it's color scheme and everything. Please let us know!
I have noticed I cannot update my site because it change from Visual composer to WPBakery. Is there an update for this? It's telling me to contact my them creator for an update.
first - provide me an url to your website
Here you are : http://palapalco.com
Thanks for your reply
I sent you the login info
Regards
AMir
Please refer to http://www.apollo13.eu/docs/ceevee/#!/installation_update_update_theme and update the theme.
It's works finely
Regards
Amir
Theme is not supported any longer and it is discontinued. I am sending you latest version to your e-mail. Please confirm that you received it.
I followed all the instructions.. this is very frustrating
I lvoe the CeeVee theme.. is it discontinued forever??
Hope you are doing well during this time!
Thank you and stay safe!
